rotor arm carbon fouling?
hi there, i wonder if u can help me with this. Drove my trusty mk2 1.3cl to work this morning,half hour into my journey car started to lose revs as if it was running on 2/3 cylinders then cut out. started with some trouble but still not much power, anyway got to work and checked rotor arm,slight carbon build up so cleaned it up with emery cloth and it is running fine now
just wanted to know if this is a common fault or is there somthing else leading to this
thanks for your help on this [/b]
thanks but is there a way to prevent this? it happens when engine is warm as opposed to when its cold
steveo3002
