check these out! i honestly think these are the deepest sets of dishes ive seen so far. going for cheap as well! cant help but feel sad i cant buy them!
If you think those are wide you haven't seen Jez's old 14x9's...
14s are a bit small for mk5s too imo. Mine looked amazingly low on some 14x8 and 9s but you need massive amounts of arch work and a lot of spare chassis parts for replacing the worn down ones, my subframe had less than 10mm of clearance from the ground
