Lost sound..
clees
Lost sound..
Post by clees »
hi guys
The front tweeter on my drivers side has stopped working and i want to know whats best to do??
Can i just change it with aother VW speaker and how easy is it? etc
cheers
polo_gti21
Post by polo_gti21 »
tweeter is replaceable quite easy
tegwin
Post by tegwin »
If its just stopped working its quite possible that its a loose wire rather than a duff tweeter...
Can you check the continuity between the headunit and the speaker?
clees
Post by clees »
I can't check anything through my headunit because i have lost all visual graphics on it. The speaker has been working on and off and recently it has just stopped all together. If it has blown then how easy will it be to purchase just one tweeter. I'm not after expensive ones really because the vw weren't bad!
polo_gti21
not quite sure if vw just sell the tweeter on its own, try using a 9v battery connect the tweeter + and - wires to that and listen if it crackles if it dose then its fine, if it dont its no good, check the wires from head unit to speaker and see if they are broke or split coz it may just be earthing out.
