how big and where do i drill the airbox on a 1.4 for an induction sound? pics would be a great help
thank yoooo
ps any side effects or issues
drilled airbox
skyline.99
drilled airbox
You want to drill the holes so that the air still passes through the filter. Id do the side if i was you. If you're unsure take the lid off and look inside. You should have a donought filter. Drill outside it.
Side effects: Faster acceleration
not to go abck on what the other dude has just said but... would it really make a difference?? The airbox on the polos is fairly spacious anyway so must hold quite a bit of air already? Im no expert though. Maybe im wrong. But err... imo i dont think it would make a difference.
How much air does an engine take in anyway??
JarnoVWPolo6N
skyline.99
acceleration
of course an induction kit is going to be slightly better but if you dont have the money then its still ok to drill the box. I recon it would still make a bit of an improvement. My oem box is very restrictive compared to the air filter i have now. Acceleration would still be improved if drilled imo.
JarnoVWPolo6N
Re: acceleration
I'm willing to bet 1.000 euro on the contrary m8skyline.99 wrote:of course an induction kit is going to be slightly better but if you dont have the money then its still ok to drill the box. I recon it would still make a bit of an improvement. My oem box is very restrictive compared to the air filter i have now. Acceleration would still be improved if drilled imo.
Shark-Polo
try a green air filter - incredible sound
[img]http://www.bebo.com/PhotoAlbumBig.jsp?P ... 762784[img][/img]
