brake pedal squeeking
trikstar
Post by trikstar »
my break pedal squeeks when i press it and the sound is coming from the outside. a mate has the same problem - any ideas?
also, anyone got any wheel spacers for sale/donation??
:lol:
cheers
pip_polo
Post by pip_polo »
i think bobtknob has wheel spacers for sale.
have a look in for sale section.
trikstar
Post by trikstar »
cool
any ideas on the brake squeeking
djc.
Post by djc. »
Rear brake shoes need greasing
LeMeph
Post by LeMeph »
I ahve issue with my rear breaks aswell. they clang when you put your foot on the peddle. Its odd.
Do everybody else brakes sort of err... whistle aswell? When i apply the break it whistles a bit sometimes. No change in braking mind. Brakes well enough, im not dead yet am i? lol.
Petrol_Head
Post by Petrol_Head »
Iv got the same thing.. if you want to change it yourself ...you can.. but remeber your messing around with your breaks... if you dont know what your doing you could really screw your car up.
Anyway.... i would recomed getting the haynes manual....
Check this web page out... it shows very clearly how to clean thse rear brake.....
http://www.focushacks.com/index.php?modid=48
Taking the hub off is fairly different to what you see in the web page
you have to prise off the center cap with a small flat screwdriver and hammer... then take a split pin out and then undo a bolt... then after that release the handbrake and carefully with a little force take the drum brake shell off.
What i did was spray brake cleaner in the drum... unfortunately that didnt cure the problem... im gong to have to take all the springs apart... and really clean one of the bits of meatal that is rubbing.
I really recomend looking at the pics on the web page before doing anything and also buying the haynes manual... Goodluck if you attempt it.
trikstar
Post by trikstar »
good stuff - i'll get onto that straight away
david burton
Post by david burton »
I'll bet that it's not the brakes if it's just a single squeek when the pedal is pressed - it'll be the distributor block thing that controls how much pressure goes to the back brakes. the black mk4 did this.
have a look under the car nearside rear door / wing. there's a block with all the brake pipes going in, they get corroded and don't work as well, wd40 it with some lube, and that might cure it.
mysteryboy
Post by mysteryboy »
LeMeph wrote:I ahve issue with my rear breaks aswell. they clang when you put your foot on the peddle. Its odd.
yea I get this at times.... changed the pads & discs and still does it at times... :?
trikstar
Post by trikstar »
i'll have a look.
the noise happend everytime i put my put on the break when the car is in motion. sometimes it even does it when i take my foot off the pedal...
david burton
that's almost certainly what I've said then, just have a peer under when the pedal is pressed and you'll see the moving part. whack some wd40 on it.
trikstar
Post by trikstar »
thanks buddy, you know your sh*t
Petrol_Head
what!!!!!!!!
did it work... just spraying the cable????
does it look like a black junction box where 4 metal rods enter into near the exhaust....
If it is... I'L go an do it now!!!!!!!
trikstar
Post by trikstar »
havent had a chance to try it - the missus has taken the car out!!
david burton
Petrol_Head wrote:what!!!!!!!!
yes, there;s some moving parts on it. grease it up / wd40 with some lube and then force it open and shut with a lever of some sort to really get the lube worked in.
