Strut Braces
SimonCorrigan
finally fitted
Post by SimonCorrigan »
finally got these fitted top and bottom and has made a massive difference. also fitted cross drilled zimmermann discs and mintex xtreme pads from gsf so corner and stops better.
david burton
Post by david burton »
isn't the diesel engine bay crammed with things over the driver's side top mount? I certainly had to remove that stuff when doing my springs.....
dino
Sponsor
Post by dino »
yeah you have to remove the black box over the drivers side strut to bolt it on.
SimonCorrigan
not too sure as they popped them on while servicing the car only took an extra 30mins or so. just need to cut the lower engine tray thingy to fit around the lower strut brace.
