Car stalls when clutch is down
Well my car occaisionly used to stall while i had the clutch held in, say as approaching a junction or whatever, which i thaught was a bit weird, but lately its been doing it all the time, and its got to the point where im stalled on roundabouts so is dangerous. I took it into my local mechanic who thinks it might be the air control valve which would need cleaning or possibly replacing, but wasnt sure and needs to ask the other guy whos in on Monday. Any ideas what is causing this, or what needs to be done?
Also on another note, because Im a delivery boy (woah!) for a living, my mate at work suggested sticking the car in neutral everytime your on a downhill to save petrol (as were allocated a set amount of petrol money.) Other than the lack of control, is there any risk to the car doing this?
Cheers x
Cheers x
Re: Car stalls when clutch is down
Wouldn't advise it as the engine has no control and is still running and using fuel.JoeG07 wrote:Also on another note, because Im a delivery boy (woah!) for a living, my mate at work suggested sticking the car in neutral everytime your on a downhill to save petrol (as were allocated a set amount of petrol money.) Other than the lack of control, is there any risk to the car doing this?
Cheers x
I was always taught to use a low gear down hill rather than using the brakes as if your using your brakes continuously down hill and then need to stop quickly, how do the people behind you know you're stopping and not just reducing your speed to stick under the limit.
dragon_green
black magic 16v
monkeyalan
your workmate is a fool. tell him i said so.JoeG07 wrote: Also on another note, because Im a delivery boy (woah!) for a living, my mate at work suggested sticking the car in neutral everytime your on a downhill to save petrol (as were allocated a set amount of petrol money.) Other than the lack of control, is there any risk to the car doing this?
Cheers x
modern fuel injected cars don't use petrol when going downhill if you don't have your foot of the accelerator, so you'd use more by sticking it in neutral. it would also be quite dangerous and stupid.
- pip_polo
monkeyalan wrote:your workmate is a fool. tell him i said so.JoeG07 wrote: Also on another note, because Im a delivery boy (woah!) for a living, my mate at work suggested sticking the car in neutral everytime your on a downhill to save petrol (as were allocated a set amount of petrol money.) Other than the lack of control, is there any risk to the car doing this?
Cheers x
my car stalls every now and again coming to junctions, i just whack it in 3rd and 'bump' it off again. not really that much of a problem i don't think?? lol
monkeyalan
My 1.0L mk4 has started doing this 75% of the time i put the clutch in when slowing down, just bounces the revs abit as it trys to stall then it cuts out!!
mine also has started doing it on roundbaouts meaning the powersteering turns off and its very hard to turn and ive nearly crashed a few times because of it!
i dont have a clue what it could be grr its soo annoying
