Finally fitted my BMC :D
Kam Racing
Post by Kam Racing »
finally got round to fitting it yesterday. pretty easy to fit, though had to trim the silicon bend to get it to fit under the bonnet as the silicon bends are larger than the rubber bends they used to supply. Certainly feels a lot more responsive now and it now has a deep growl :thumbsup:
alexperkins
Site Admin
Post by alexperkins »
Nice job. It does look good in silver. I received my last filter in the post yesterday :) Fitted it and works a treat.
im just glad I had some pipe lying about to channel the crankcase breather down the front away from the air vent for the interior - fumes are rather unpleasant :P
partridge88
Post by partridge88 »
sweet that. how much are they?
would you see much gains without a remap?
I'm curious as to where the cold air feed is on the 6n2, usually feeds are behind the front grille, its funny to see an airbox so far from the front of the engine bay.
alexperkins
Site Admin
Standard air feed goes into the left wheel arch - follow the pipe:P
They cost £160 - jon (kamracing) was doing a group buy for a little less or that if i remember correctly, but that might be over now.
You should gain 1-5hp depending on your setup.
Mouse_GTI
Post by Mouse_GTI »
I can no longer smell the fumes from my breather filter. Or maybe I'm used to it
Kam Racing
partridge88 wrote:sweet that. how much are they?
BMC's dyno recorded just under a 6 brake increase with the BMC over the OEM filter but not sure whether they remaped it after.
I can do you a silver one at the GB price as one guy pulled out...
http://www.kam-racing.com/product_info. ... cts_id/474
if your after a black one i'd have to order it in as i've just run out of stock... should only be a couple of days extra to wait though...
New B
Post by New B »
Mouse_GTI wrote:I can no longer smell the fumes from my breather filter. Or maybe I'm used to it
I had the same thing I just stuck my engine cover back on
alexperkins
Site Admin
I got a bit of rubber pipe from a scrappy, and piped the crankcase breather all the way down to behind the front left foglight next to the fuel filter - solved all the problems heheh :D
tomo87
Post by tomo87 »
mine is definatly the wrong way round! will that make much difference?! lol
alexperkins
Site Admin
Howd u mean - the bmc is round the other way?
In a non-gti/non16v engine, the throttle body is in the middle, which means there isnt enough space to point it left. Mine points towards the coolant tank i have that problem:P
tomo87
Post by tomo87 »
im confused....mines a gti - but the side that says "engine side" is facing the car
Redline
Sponsor
Drives: BMW 128ti
Post by Redline »
The end labelled "engine side" should be the end connected to the 90 degree bend off the throttle body.
tomo87
Post by tomo87 »
im all good then! cheers mate
