Can you help? Polo cutting out.
jaydoubleu
Post by jaydoubleu »
I have a VW Polo 1.6 GLX 1996 (P Reg) 74,000mls.
The car runs well apart from a niggling problem of cutting out intermittently.
I can be driving along fine and the engine/ignition just cuts out - I pull into the side of the road, switch off the ignition, switch on again and the engine re-starts immediatly.
It sometimes dies as though it is about to cut out but I can (sometimes) manage to get it to cut in again if I change down a gear - this can happen 2 or 3 times within 20 or 30 yds and then it will drive great for the rest of the journey.
I have recently had a diagnostic test which gave an error message of "00519 ma,fold Absoltute Pressure Sensor Not a plausible signal occurs intermittently"
This resulted in having the M.A.P Sensor replaced.
However, yesterday I took the car on a journey (approx 40 mls round trip) within approx 1.5 mls the problem returned, the car ran great for a further 15 mls before reoccuring.
It is allways when I am in 5th gear and mostly when going driving up hill.
This is the general pattern of things.
I would appreciate any suggestions on how this problem might be resolved.
PoloPower
Re: Can you help? Polo cutting out.
Post by PoloPower »
throttle body potention meter ..
40 - 60 Squid is in price ..
Mine did it too ..
They all get a bit dodgey ..
Well i have been told ..
Hopefull ythis helps
