Servicing
polokaj
Servicing
Post by polokaj »
Hello ppl
Have a 1.4 16v and was just wondering what is required when servicing a car. Heres a list of things i could think of
Spark Plugs
Air Filter
Oil Filter
Oil
there must be more? also what type of oil would you recommend.
JoeG07
Post by JoeG07 »
leads as well will probs need doing, m ylast service i had oil seals, brake pads and shocks changed but thats was a full on service
dragon_green
Post by dragon_green »
check your brake pads and discs have plenty of meat left on them.
shocks are not really something you'd replace as part of a service.... but do check that they are damping correctly.
Check gearbox oil
Check coolant level
Check brake level
Check dizzy cap.
It's ALL in the HAYNES manual. Whats more, it will tell you how to do it. magic.
polokaj
Post by polokaj »
thanks guys, ive been looking for a haynes manual for the 16v but havnt been able to find one.
what am i actually looking for on the distribuator cap>
polokaj
Post by polokaj »
also how much oil is normally required. thanks
dragon_green
a 5 litre bottle should see you right. again, the full spec is in the haynes....
alexperkins
Site Admin
Post by alexperkins »
The mk5 1.0 takes approx 3.5 litres of oil so 5 litres is more than enuff :)
dunces6
Post by dunces6 »
whats the millage on it and has it ever had a cam belt and water pump
