Clay bar question ...
Detailing & Bodywork
Post by 8080 »
I only used mine twice :( It had picked up specks of grit - i should have washed my car more thoroughly though!
Ollie_R
Sponsor
Post by Ollie_R »
If you used the whole bar of clay, it'd be worth getting some new clay. Next time you use it (twice a year should be fine) cut the bar into halves, that should keep it lasting longer. 5 times is the maximum for clay really.
I'd recommend some Sonus Green clay, it's much better than the Meguiar's clay. Available here.
Mouse_GTI
Post by Mouse_GTI »
You just need to keep folding it until you get a clean side, when you can't then you know it needs replacing 8)
GTI V
Post by GTI V »
Yeh definitely go for the Sonus green one.
I cut mine in half. and so far have used it twice.
The car was in pretty bad knick.
I won't be using it again. Will use the other half now.
Dee-vub
Post by Dee-vub »
i'v just gone for the poorboys medium clay as a change from the meguiars so will give my verdict soon enough 8)
