The reason I've not wired them in is because I can't find the wires that become live when the indicator circuits are activated
I've looked at the wiring diagram in my Haynes, and from what I understand, the left indicator circuit is a Black and White gauge 1.0 wire and the right circuit is Black and Green gauge 1.0. According to the diagram, these wires are next to each other in the switch harness, but none of the harnesses have this combination, also I have tested those colour wires and other wires that I can find with a multimeter to earth, and I'm not getting a 12v reading when the indicators flash
There are quite a few wires under the steering column, coming from the various switches, and I'm well and truley confused
Can you help me locate these two wires that I require. Thanks in advance.
