with the bottom pulley on the timing marks (no 1 piston firing) it should be somewhere around here
thanks to me pops and jarno for helping me
your welcome m8, already started the engine? Didn't have to time the belt and ignition by hand? (I hope you've checked this both before your started the engine, to make sure your valves won't be hitting your pistonsneb wrote:thanks to me pops and jarno for helping me
Didn't use the trick with the long screwdriver throught the spark-plug-hole? With that you can really "fine-tune" the timing of the opening of the inletvalves, to make the engine suck in as much air/fuel mixture as possibleneb wrote:yep turned the engine over by hand before starting, i ran it and all seemed fine but i still had the ignition timing on the standard position.
it was abit of luck as the belt timing was spot on first time!
cheers, i'll give it a go. ran it properly today and it definately gives you more oomph past 2500rpm.JarnoVWPolo6N wrote:Didn't use the trick with the long screwdriver throught the spark-plug-hole? With that you can really "fine-tune" the timing of the opening of the inletvalves, to make the engine suck in as much air/fuel mixture as possibleneb wrote:yep turned the engine over by hand before starting, i ran it and all seemed fine but i still had the ignition timing on the standard position.
It's got a longer duration, which means your valves will by opened longer, therefor making it easier to suck in (more) air-fuel mixture and breath out the exhaust gasses, giving you mroe power and torque. No further adjustments needed here, just a proper fitting and checking of the ignition and timing beltHardcore wrote:nice. glad to know about this. just gota get my hands on one now lol.
do you need to alter anything else to make it fit? and does it wear anything down or owt faster?? if im making sence...
Nope, same one, but original ones have plastic interior, new ones metalHardcore wrote:ok mate. thanks. do i need to alter the water pump is it highyly important :S
ill do it anyway though. what am i looking for? a bigger one??
