Polo GTI: Central Locking failed
kraized
Post by kraized »
Hey,
I drive a late 2001 model Polo GTI 16v. My central locking pump has failed - the PCB has got wet and burned out :(
VW want £180 plus VAT plus £70 ph labour to fit a new one. I am wondering whether any of you guys know where to get one cheaper. Mine is an 8-pin model with part no. 6NO 962 257 A. On eBay I can only find 10/11/12 pin models with slightly different part nos. Will those work?
Cheers guys. Oh BTW. First post. :lol:
Si_GTi
Moderator
Post by Si_GTi »
Welcome to uk-polos!
I recognise that picture, did you buy your GTi from Jersey then? (assuming that is your car in the picture!)
MaxZ
Post by MaxZ »
Any of the mk4/mk5 polo central locking pumps will fit, it's extremely easy to replace it, you just unplug old one and put new one in, it's underneath the first aid kit in the boot.
I'm pretty sure there's one for sale on CP
h4r1s
Location: Leicester/Sheffield Drives: Polo MKV-6N2 1.4SE 16v 75BHP
Post by h4r1s »
mk3 golf ones fit as well, and i think you'll be able to find plenty of them on ebay or at the scrapyards
hope that helps
thedees1
Sponsor
Location: edinburgh/livingston, drives: polo gti red 5dr
Post by thedees1 »
i got one off ebay for £16 all in :D
vdubit
Post by vdubit »
I have a mk4 golf cabrio one in my car. Central locking dont work but that aint the reason!
kraized
Post by kraized »
Hi guys, thanks for all your comments. So I take it for example a 12 pin pump will work even though I have an 8 pin one? I guess the extra pins just wont get used.
Simi
Post by Simi »
I have replaced the pump on my car, the car now locks but is not unlocking. I have tested the circuit, it is getting power to lock but not to unlock. Any ideas why this might be?
vdubit
Post by vdubit »
Is this just off the remote or the same if you use the key in the lock? Mine won't unlock from the remote, but it deactivates the alarm.
kraized
Post by kraized »
Well. I have got a new pump off of eBay. £20. Thing is the air hose connector is slightly different to my old pump. I think I can get round it by cutting the connector off the hose and just pushing the host directly onto the pump.
Though the main problem is that the arrangement of the electrical contacts is different to my old pump. My old pump is an 8-pin pump. I couldn't find an 8-pin one on eBay so I got an 11-pin version. I'm thinking I can just move one of the pins in the connector thats attached to the car, then they will all make contact with the new pump if I move just one pin. Would this work? Should I try and find an 8-pin pump instead?
Cheers.
[EDIT]
Well I tried the above and it didn't work. Can't get the pins out of the connector. So I guess I am on the lookout for an 8-pin (with the same pin arrangement as mine) or a 12-pin pump. :?:
kraized
Post by kraized »
Simi wrote:I have replaced the pump on my car, the car now locks but is not unlocking. I have tested the circuit, it is getting power to lock but not to unlock. Any ideas why this might be?
vdubit wrote:Is this just off the remote or the same if you use the key in the lock? Mine won't unlock from the remote, but it deactivates the alarm.
Hey guys,
I have now finally replaced the pump on my car but I am now having the same problems. I can't unlock the car via the remote but it deactivates the alarm :( Its locks fine with the remote and the door lock/unlock buttons work fine on the drivers door.
Have you guys found a solution?
vdubit
Post by vdubit »
Mine still not resolved. I did however speak to an autoelectrician who believes its the comfort module, which is apparantly up in behind dash somewhere. It also sounds expensive :cry:
I'm contemplating ripping out all the air solenoids and running the system off of electric solenoids. That way i can get one of those cool flip keys as well and tap into the factory alarm.
alexperkins
Site Admin
Post by alexperkins »
Comfort module is over £200 wonderful english pounds!!
kraized
Post by kraized »
What the hell is a comfort module and what does it do? And what does it have to do with the central locking? God. Nothing is simple these days. :roll:
alexperkins
Site Admin
Controls alarm, electric windows, central locking, ac loads of stuff. Its quite an important little box!
