Ooh, uh, well, I haven't got a picture, but I'll try to explain at my best in english.
Ok, your clutch-cable is easy to spot, since you all drive on the left side of the road, I don't know where it is mounted, but just have someone else sit in your car, while you look under the bonnet, let the other person step on the cluthc, and you'll be able to spot your clutchcable
There's a wrinkly thing on it, around near the spot where the cable is being supported, on this spot you can peal back some of the cover, the wrinkly thing can open so to speak, and here you can spray in WD-40, then clutch couple of times, and keep doing this. Another part to spray your WD-40 on is the lever on the gearbox which is controlled by the clutch cable, just let the other person keep clutcing, look at your gearbox, then you'll know what I mean
spray that in good, will stink next time you get your engine good hot, but that doesn't matter
