polo mk4 speedo, faulty milege display,can used parts fix it
dub fatha
Post by dub fatha »
hiya
need some advice please before i rip my speedo apart,
i have an s reg mk4 polo 1.9 diesel which has a faulty milege display.
some of the pigments (i think thats how its spelt) have died and you can only see the bottom half of the milege.
i have a second hand speedo from a petrol model, and was going to use the bit that displays the milege and fit it into mine,
not sure if this is accurate bit i was told that the immobiliser runs through the speedo like the mk4 golf's.
please can someone let me know if i can fit the second hand milege diplay into my clocks without any problems from the immobiliser, and also if it will show my original milege or the milege from the doner speedo.
any help or advice will be much appreciated,
regards
dub fatha
alexperkins
Site Admin
Post by alexperkins »
A display swap should work fine - providing its only the display you swap and not the speedo memory par example!
dub fatha
Post by dub fatha »
alexperkins wrote:A display swap should work fine - providing its only the display you swap and not the speedo memory par example!
thanks for the help mate,
do you know what part is the bit that memorises the milege
alexperkins
Site Admin
A chip in the somewhere- i wouldnt be able to tell you which one sorry :(
