Immobiliser Question
rachelw
Post by rachelw »
hi, i have a 1.4cl VW Polo 1995 5 door hatchback which i've had for a small while now- second hand. Just while filling out car insurance i was trying to work out whether there is a factory fitted immobiliser on this car.
Can anyone help me? thanks!
SpikeyG40
Moderator
Post by SpikeyG40 »
firstly, welcome to the forum!
the main reason no one has replied is your car is a mk4 instead of a mk3. easy mistake, so i'll move the topic to the mk4 section and hopefully you'll have a bit more luck! :wink:
The_phat_controlleruk
Post by The_phat_controlleruk »
In answer to your question, I belive it will have. Mine is a 1998 (S reg) 1.4 L (Poverty spec) and mine has a factory immobiliser. Your keys will have a transponder in it, hence why you need to reprogram the keys if you get a new set.
willowaz
Post by willowaz »
Yeah i can second that, it will have a factory fitted immobaliser, ive got same car t-reg and my mum has a p-reg, and ive looked at quite a few others too, all have the immoby in the keys automatically. hope that helps!!
