Hi there
I'm facing a problem with my polo, not sure what the acutal root of it is
or the solution.
When i'm driving and sometimes put the clutch down, with the brakes
the reving needle sometimes goes all the way to zero and the car cuts out.
Sometimes, the car saves itself, i hear like a kickback from the rear of
the car and the needle goes up, and then when idle the needel would
move quite irraticly between 8500 and 9500 revs.
I'd welcome any suggestions, cheers for in advance.
1997 Polo Cuts out
JarnoVWPolo6N
Re: 1997 Polo Cuts out
Your trotthlebody is dead, get it replaced, is a common problem on the mpi-engined mk4'sMohan wrote:Hi there
or the solution.
dragon_green
The_phat_controlleruk
Hey
I cleaned the throttle body today by spraying it with the Carb Cleaner &
loads and loads of oil came out, there was some oil residue in the air filter
box as well, cleaned that with the Carb cleaner aswell.
the small tube connecting to the air filter I cleaned that aswell.
problem had ceased instantly, and everything running fine.
thanks again
thanks again
Nice one, glad to see it's sorted.Mohan wrote:Hey
thanks again
