signal booster
Discuss In Car Entertainment
1der
signal booster
Post by 1der »
is there anything i can buy to boost my aereial signal?
Hardcore
Post by Hardcore »
dont think so.
try bass junkies or somewere.
do you have bad signal on your radio?? is it a standard radio? most polos have pretty good signal i found:S
jonboy
Post by jonboy »
you can get amplified ariels, so im fairly sure someone must sell just the amp. most bea-sting ariels are amped anyway, so it might be that yours has seen better days. they tend to fail if the rubber grommit has cracked, water gets in and kills the little amp. have you had a look on egay?
Bepe
Post by Bepe »
yes you can get power boosters to boos your signal, get them from halfrauds!
Charlie-Boy
Post by Charlie-Boy »
Hello mate i had the same problem wanted a stronger signal... halfords have a signal booster which i bought but didnt fit my stero what a bummer lol but should be all good mate cheers
1der
Post by 1der »
forgot about this post :lol:
thanks for the advice guys. dont need it now as got a different aerial so alls good
