Firstly no disrespect to mk4 glx 1.6 for posting a brilliant and thorough walkthrough on this procedure. But for those of you who would like an alternative to taking the bumper off please read on.
Firstly I recommend reading through mk4 glx 1.6 thread http://www.tigerstyle.co.uk/poloforum/v ... =sidelight
these are the tools you might need. Notice there is a mirror too!
Next, in order to remove the indicator unit, twist the small black plastic headed lock that is indicated in the picture, so that the "pins" are parallel with the car i.e one facing the front bumper, one facing the windscreen (as indicated in the picture). caring out on both sides.
simply remove the unit by pulling towards the front
Now remove the air intake hose, and disconnect the HID cable, simply pull back the sleeve, then twist the connector off. Much like a household light bulb (bayonet).
Now you will be able to unscrew 3 screws securing the headlight cover and pull off. The images below are 'Stolen' from mk4 glx 1.6 walkthrough. They are merely to show the location of the 3 screws
Next undo the bolt securing the battery. Undo the negative terminal. Then swivel the battery towards the engine like so. Disconnect the HID cable
Now it is time to fit your new sidelights. If you have read mk4 glx 1.6 thread this part is very straight forward. Simply pull out the sidelight housing, and replace the old bulbs with your new ones.
reconnect your battery temporarily and check everything is in working order before reversing this procedure.
1. Disconnect the the battery again.
2. Replace the the headlight covers (both sides).
3. Screw in the 3 screws (both sides).
4. Reconnect the HID cables (both sides).
5. Replace the indicator units (both sides).
6. Reposition the battery. resecure and reconnect.
7. Reconnect the air intake hose.
8. Congratulations I think your done!!!!!!
