1st gear problem???
1st gear problem???
Im having a problem putting my 1.4cl into 1st gear i no it sounds daft but when im trying to put it in it seams to possibly hit some thing and wont go in. it used to do it very rarly but now its nearly all the time.
Can any body help with why this could be happening or a way to solve it??
The_phat_controlleruk
Is that with a new clutch and bearing??, mine's just gone so I am also after a new box now. Why is it so many boxes failing???iggy350 wrote:well it could just be the bearings or sumut little tbh m8.
you might beable to get a cheap repair. Try your local top gear garage. I have just booked mine in for a referb Gearbox which has cost me £320
dragon_green
dragon_green
First off, change the gear box oil and add decent oil to it, Make sure the clutch is adjusted proply! Also make sure you dont try to force it in, if you are still rolling allong the road, slow down more before selecting the gear, put pressure on the gear stick into the gear and slow down untill it slips in.
It will be down to general wear, VAG Gear boxes are the weekest part of any VW, Just ben gental and change oil every now and then and it should last for many miles yet.
