Polo GTI: Central Locking failed
Simi
Post by Simi »
i have several problems! 1st of all the central locking does not work, have tried a new pump and it locks, but then wont unlock. Drivers side electric window does not work, and when you control the passenger window from the drivers door it will go down, but when you try and get it to go up again, it goes down! if you push in the rear window heater, the passenger window then goes down when it should go up, and up when it should go down! :?
alexperkins
Site Admin
Post by alexperkins »
Sound like some serious wiring issues - make sure the door join for all the cables is nice and tight. Other than that, get an auto electrician on it!!
The drivers and passenger motors are linked directly, so this could relate to your problems
