LED light conversion kits....Guaging interest.
tegwin
Post by tegwin »
Thats the kinda effect im trying to achieve on all of the lights....
Given the unbelievable performance of some of the newer LEDs, replacing the fog and reversing lights with something that will be better is not a difficult task and should finish off the set!
Bepe
Post by Bepe »
i would be up for the rear side lights and brake lights in LED Format, you able to do front sidelights like so?
http://blogs.edmunds.com/.ee96a96/cmd.2 ... e..ee96a97
tegwin
Post by tegwin »
Fitting sidelights like that would get complicated...An interesting thought though, and something to be considered!
I have just ordered several thousand high intensity LEDs and a shead load of other shiny bits, so hopefully next week I can put together a trial set :-)
Im thinking of having the brake and sidelights linked so that, when you have the sidelights on they are dull (As they are suposed to be!), then when you apply the brakes, the brakelights come on, and the sidelights get brighter....
Would look cool and make the fact you are stopping a bit more obvious :shock:
Bepe
Post by Bepe »
sounds good mate, keep us updated
