Rear lights
sorted
Rear lights
Post by sorted »
Seen a few people with the hella leds in standard red mk5 lights... did they take the red lense off then fit the LEDs - or did they do it from the back (drilling etc?)
Neildo
MaxZ
Post by MaxZ »
I'm pretty sure they are bonded, so put them in the oven and heat them up
sorted
Post by sorted »
MaxZ wrote:I'm pretty sure they are bonded, so put them in the oven and heat them up
Surely that wouldnt work ?
MaxZ
Post by MaxZ »
Heat up and loosen the glue? Thats how you take headlights apart
sorted
Post by sorted »
MaxZ wrote:Heat up and loosen the glue? Thats how you take headlights apart
Would it not melt all the other plastic though ?
MaxZ
Post by MaxZ »
I'm not saying you have to put it in the oven for a day, just long enough to get the glue to unbond, I know a few people who have taken their headlights apart that way with no problem
sorted
Post by sorted »
Done a quick google and it looks like thats the way to do it - might try it 2morro
Cheers!
Post by 8080 »
The lad I know who did it cut the brake light segment out from the back with a Dremel.
I don't think the oven will work - afaik they're not glued. Just a transparent layer of plastic on top of a red/white/black layer of plastic, hard to explain
sorted
Post by sorted »
8080 wrote:The lad I know who did it cut the brake light segment out from the back with a Dremel.
I see... i had a set of Hella lights - that i took the LEDS out. I tried these in the oven last night - and i couldnt get them split atal - so it looks like it might have to be from the back + glue :lol:
sorted
Post by sorted »
Well....
Ill put a pic up of them on when im out later .... kinda unexpected results though!!
sorted
Post by sorted »
2morro going to try glue the LEDS to the inside of the lens and see if that makes them come out more as DOTs rather than just like a bulb but much brighter !!
alexperkins
Site Admin
Post by alexperkins »
The problem with rear lights is theyre full of little reflective and refractive parts to ensure a bright and consistent light - unless these LEDS are really close to the front of the lens (like you say), you wont get the pattern your after.
sorted
Post by sorted »
Yup, as this is the first time trying it I never really knew what to expect.
I'll try put them closer later!
About the wheels im not sure, 350 delivered?
alexperkins
Site Admin
sorted wrote: About the wheels im not sure, 350 delivered?
what wheels lol!?
sorted
Post by sorted »
what wheels lol!?
http://www.tigerstyle.co.uk/poloforum/v ... hp?t=34130
