Cost of Timing Belt Replacement
pepitopinoy
Post by pepitopinoy »
Got a 50T miles service today. VW advice that my timing belt is due for replacement - Price £385 all in + 1 of my rear bumb stop is broke. Price £259all in.
Just want to know if i am quoted too high or just right?
alexperkins
Site Admin
Post by alexperkins »
Sounds about right for a dealer. Id get the water pump changed at the same time, otherwise thats a rather expensive job if the cambelt isnt changed at the same time as it all has to be removed and re tensioned.
alexperkins wrote:Sounds about right for a dealer. Id get the water pump changed at the same time, otherwise thats a rather expensive job if the cambelt isnt changed at the same time as it all has to be removed and re tensioned.
Exactly, plus the genuine VAG waterpump is an exchange part so does not cost a lot - some people say that doing this is a waste of money - but if the waterpump fails in 35Ks time then you will be a bit sick! I certainly got mine changed along with the cam belt + all the tensioners etc. The original pump impellar was hard plastic - the new pump impellar was metal - I wonder why? One other thing, if your engine is a petrol 1.4 16V then the top idler wheel is not included in the kit "does not need it" VW say, well my VAG indep guy said that he changed mine as that idler wheels sometimes siezes and is the cause of the belt failure - you have been warned, by the way this idler wheel has the same number as the one for the PDI engines - it does not show up in the 1.4 16V parts list - it is only available as a complete assembly, ie fitted to a mounting bracket.
pepitopinoy
Re: Cost of Timing Belt Replacement
pepitopinoy wrote:Got a 50T miles service today. VW advice that my timing belt is due for replacement - Price £385 all in + 1 of my rear bumb stop is broke. Price £259all in.
Got the rear bumb stops(both rear bump stops) done at a volkswagen specialist garage here in belfast for just £45 all in. I also booked for the timing belt and water pump replacement and they quoted me £275 all in.
:D
And they also do an MOT preparation for me for just £35.....
