Coolant replacing
dantheram
Coolant replacing
Post by dantheram »
Can someone tell me how to replace the coolant in my GTi. I know where the reservoir is but i have no idea how to drain it and replace the coolant.
Cheers,
Dan
Ian_R
Post by Ian_R »
Well make sure its cold for a start, dont come home and think i'll do the job as the water will be hot!
Basicly all you should have to do is unplug a pipe from the radiator and let it drain out, then refill with colant and water and bob's your uncle,
Dont take this as Gospile and either read a haynes manual or get a mech to do it.
alexperkins
Site Admin
Post by alexperkins »
Bottom radiator pipe, and expansion tank cap off. Itll all drain out. After refilling, you need to ensure you squeeze the radiator pipes with the tank cap off still to eradicate any air bubbles from the fluid.
As ian says, follow the haynes manual for it.
bbspolo
Post by bbspolo »
The above ways work fine but if u want 2 be rearly clever u can buy an adapter from snap on that will screw into the expansion bottle were the cap normaly sits then u can plug a hose pipe into it, then with the bottom hose pipe off u can leave it for 20mins or so and it will completley flush the coolant system out (u will be amazed how much s**t comes out)
This is what i do at work (vw dealer)
olop_chris
Sponsor
Post by olop_chris »
Why not save money and just stick a hosepipe in the tank anyways?
Thats what i do...did it yesterday infact! :)
alexperkins
Site Admin
lol :D
bbspolo
Post by bbspolo »
Cause it doesnt create any pressure in the system so doesnt get half the s**t thats stuck 2 the walls of your rad out ! :wink:
I get paid 2 know this s**t :lol:
