ABS light
PDA
ABS light
Post by PDA »
Hi
The ABS light has start to come on in the missus 9n, comes on for a bit and then off when the car is restarted then back on for a bit a couple of days later. Any one got any ideas what the issue could be.
chris4500uk
Post by chris4500uk »
I'd get it checked out with a Vag-com, find the exact fault
Could be a number of things, I think it also might come on when the pads are getting low.
Could be a faulty sensor
alexperkins
Site Admin
Post by alexperkins »
It could well be a faulty speed sensor. Vag com it for sure
Jamo
Post by Jamo »
I don't think it will be the wear sensor on the pads as this brings on a different warning light - I think....
It could be a sensor on its way out or the ABS ring coming loose... on my old golf I had a similar problem and it was caused by a stick caught behind the front wheel getting between the sensor and the ABS ring.
VAGcom is accurate to a point but will only point you in a rough direction.
Good luck :wink:
PoloRally
Fuse
Post by PoloRally »
The fuse is good place thats what happend to mine then it stayed on replace the fuse and should be ok.
