LED Sidelights
- KennyPOLO_Gti
- Platinum Member
LED Sidelights
Has anyone fitted L.E.D sidelights to their car? If so how did u connect the the reisitor and scotch lock? Dont wanna go stabbin into the wires n fek it up! Ya see am a mechanical fitter so am a bit rough when it come to these things!
- Tim_GTi
- Post Whore
Kenny are you on about a load resistor kit?
http://www.ultraleds.co.uk/loadbsolutio ... p-429.html
these are to stop some sort of warning popping up that newer cars detect, (they think somethings wrong because of the low power consumption ised by LEDs)
there's a little bit of information on them on here
bottom of the 2nd page and 3rd.
http://www.tigerstyle.co.uk/poloforum/v ... c&start=15
- KennyPOLO_Gti
- Platinum Member
I have had led sidelights in my car for over a year with no warning light problems or fault code issues. My 9n3 was hooked up to VAG com last week and no faults found. Unless I'm very wrong you do not need to worry about a resistor kit on a 9n3 - do not cut or splice your loom!!!!
Have a look on www.ultraleds.co.uk for the bulbs - they are 501 wedge type. There is not the clearence for the multi type LED sidelight bulbs in the headlights though so buy the shortest ones they sell, the staff there are great if you want to phone them to check your ordering the right ones.
- KennyPOLO_Gti
- Platinum Member
I got these ones from hid4u, think there the same as ultraled ones:
501 LED High Power 1W Upgrade Bulb
http://www.hids4u.co.uk/store/product.p ... t=6&page=1
So i dont need the load resistor then!? thank god a neva went a fitted it or attempted too!
- KennyPOLO_Gti
- Platinum Member
- KennyPOLO_Gti
- Platinum Member
- KennyPOLO_Gti
- Platinum Member
