VR6 South
Posts: 194 Joined: Mon Apr 19, 2004 6:58 pm
Post
by VR6 South » Fri Feb 08, 2008 5:32 pm
Has anyone had problems with their rear wiper? Mine goes for a couple of inches and stops then starts again. Jittery is the best way to describe it It's not related to the wiper blade as that's new
ModifiedMadness
Sponsor
Posts: 6769 Joined: Tue Jun 14, 2005 8:38 pm
Post
by ModifiedMadness » Fri Feb 08, 2008 5:46 pm
Yep, it judders on the first wipe then as it comes back to where it started it's smooth.
VR6 South
Post
by VR6 South » Fri Feb 08, 2008 5:50 pm
ModifiedMadness wrote: Yep, it judders on the first wipe then as it comes back to where it started it's smooth.
I'm not alone then. Any ideas on what the problem is?
alexperkins
Site Admin
Posts: 14874 Joined: Sat Nov 11, 2006 5:29 pm
Post
by alexperkins » Fri Feb 08, 2008 6:21 pm
Its to do with the tension on the wiper blade. A new blade often sorts this - depends on the condition of the rubber, so it jumps as its not fresh anymore.
VR6 South
Post
by VR6 South » Fri Feb 08, 2008 6:25 pm
alexperkins wrote: Its to do with the tension on the wiper blade. A new blade often sorts this - depends on the condition of the rubber, so it jumps as its not fresh anymore.
I have fitted a new wiper blade. The jerky movement is different from when you have a juddery/goosed wiper
alexperkins
Site Admin
Post
by alexperkins » Fri Feb 08, 2008 6:39 pm
What kind of jerk is it then?
Tim_GTi
Post Whore
Posts: 12289 Joined: Mon Jun 25, 2007 6:31 pm
Post
by Tim_GTi » Fri Feb 08, 2008 6:54 pm
Is your rear window clean?
Even though its a new blade there could be friction because of dirt
VR6 South
Post
by VR6 South » Fri Feb 08, 2008 6:59 pm
alexperkins wrote: What kind of jerk is it then?
It's almost like the wiper motor is pausing for a bit. I have the same problem on both Polos
Tim_GTi
Post Whore
Post
by Tim_GTi » Fri Feb 08, 2008 7:03 pm
I get this on my front wipers too, I've always put it down to them being aftermarket aero wipers, I tend to not really worry about it
andyg
Posts: 431 Joined: Sat Jul 17, 2004 8:58 pm
Post
by andyg » Fri Feb 08, 2008 7:07 pm
My rear wiper also does this. I found that its pretty useless anyways, just like the washer that always pops off and leaks into my carpet.
VR6 South
Post
by VR6 South » Fri Feb 08, 2008 7:09 pm
I might spray some white grease on the linkage to see if there's any improvement.
Tim_GTi
Post Whore
Post
by Tim_GTi » Fri Feb 08, 2008 7:10 pm
andyg wrote: My rear wiper also does this. I found that its pretty useless anyways, just like the washer that always pops off and leaks into my carpet.
Hence the best option being de-rear wipering
VR6 South
Post
by VR6 South » Fri Feb 08, 2008 7:17 pm
Tim_GTi wrote: andyg wrote: My rear wiper also does this. I found that its pretty useless anyways, just like the washer that always pops off and leaks into my carpet.
If I removed the parts on my GTI each time they have broken I wouldn't have much of a car left
ModifiedMadness
Sponsor
Post
by ModifiedMadness » Fri Feb 08, 2008 7:35 pm
I think I must have mis-read, it's my blade that judders.
Even when I fitted a new one it started again after a few wipes!
Mouse_GTI
Posts: 2937 Joined: Sat Apr 01, 2006 10:29 am
Post
by Mouse_GTI » Fri Feb 08, 2008 9:05 pm
Mine was ok with the standard one. It's juddery with the Aero wiper as it's a very tight fit and sits at an angle against the screen
