Whinning noise when accelerating
stallion1987
Post by stallion1987 »
My polo gti makes a whinning noise when i accelerate and gets higher the faster i go has anyone had the same noise? Thanx
Luke'sGti
Post by Luke'sGti »
Does it only happen when the car is in gear..i.e. does it stop when you take it out of gear? If this is the case it sounds like your gearbox could be on the way out..sounds very similar to what happened to me. Hope that helps
stallion1987
yeah it does stop when i take it out of gear and when im changing down it sort of ticks as i slow down.
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh if the sound is speed related (i.e makes the noise regardless of whether the clutch is up or down, and gets louder the faster you go) it could be a wheel bearing,
But whinning that disapears when out of gear? sounds like the gearbox buddy :? :(
tegwin
Post by tegwin »
Depends how bad the whine is...
My car does just that and I have had the gearbox replaced!
I suspect its a bearing somewere on the engine block that only whines when its loaded....
unless it gets worse I woulnt worry too much!
stallion1987
Ok guys thanks for that . Cheers. :) :) :)
