195/50/15's on a 6n (Not lowered) - Will they fit?
Spaceghost
Post by Spaceghost »
I've tried looking everywhere on here and club polo but not really found a definite answer.
If I get some 15" wheels with 195/50/15 tyres on, will these fit on a 6n that hasn't been lowered without rubbing?
I read in the faq that you really need 195/45's, but not many of the wheel/tyre packages come with these.
If it has to be 45's then fair enough, I just wanted a definite answer!
polo gangsta
Post by polo gangsta »
mate you could put some 15" wheels on with a profile of a 100 and it still wouldn't rub because polo's come ridiculously high as standard so you should be alright with the 195/50/15, and also people normally tend to go for the 45's because then you get a bit more clearance and can lower it abit more
Spaceghost
Thanks for the response mate!
I guess I knew it'd be high enough looking at it, lol! But will they not be too big length ways? As in front to back?
Thanks for your help!
polo gangsta
even length way there is still alot of arch gap, your best bet would just be to get them 15's wrapped in some 195/45/15 and preferably some coilovers because then you can adjust the ride height at what ever you think looks good
NOZ
Post by NOZ »
No, 195/50/15s are as good as standard rims. You won't have any issues at all. Arch is big enough to cope when its at standard ride height.
Spaceghost
Nice one guys! Don't knwo if/when i'll be going down the lowering route, but I do agree it looks loads better.
I've got to ask though, if 195/50's are ok, why does the official mk4 FAQ on this site say that you should really use 195/45's? It gives the impression that 50's will rub. If the FAQ's wrong, then fair enough! It's just that it seemed a bit vague, hence why I started this thread!
bstardchild
Moderator
Post by bstardchild »
provided the offset isn't hugely different to std wheels they chouldn't rub on a car that isn't lowered or just has a small drop.....
The only big affect going to 195/50 15's as opposed to 195/45 15 is that your speedo will be out
The 50 is a Percentage of the width
So 97.5mm is the profile on a 195/50
verses 87.75mm which would be the profile on a 195/45 tyre
Look at a tyre sizing comparison site and it will tell you the percentage that it will throw your speedo out verses the correct size tyre.....
Jackdcruz
Post by Jackdcruz »
the speedo is taken from the gearbox mate, so it wont be out
Spaceghost
Jackdcruz wrote:the speedo is taken from the gearbox mate, so it wont be out
Didn't know that! This was another one of my worries, so thanks for clearing that up.
shaun_polo
Post by shaun_polo »
the speedo is affected by the size of the tyres compared to the standard ones google tyre calculator to work it out
Spaceghost
shaun_polo wrote:the speedo is affected by the size of the tyres compared to the standard ones google tyre calculator to work it out
Yeah just spoke to my dad about it, looks like Jackdcruz was wrong!
The speedo will be out, just a matter of how much.
bstardchild
Moderator
Absolutely spot on 8)
- tyres sizes can have a huge effecton on gearing and speedo accuracy
BratManGTi
Post by BratManGTi »
thing is guys you will find out that you clock is not as accurate as u think
allmost all of the time the speedo say your going faster than your are
i used to go past the local speed check ting at what my speedo said was 60 spot on and with 17" wheels wil 40s on the speed check said 58 these speed check signs are the most accurate way of telling speed as they are just as accurate as a speed gun
hope this helps
ps the m54 camera has never had me
and its known for doin people at 71 lol
bstardchild
Moderator
BratManGTi wrote:thing is guys you will find out that you clock is not as accurate as u think
hope this helps
Correct - however the issue with over sizing tyres is that the car will travel further in every revolution of the wheel - the speedo is driven from the gearbox so it is "calibrated" to run with std size tyres.
Most speedometers overstate you actual speed by a small percentage and this error increases the faster you go - thats a safety margin I'd rather have.....
Spaceghost
hope this helps
Anyone know how accurate Sat Nav's are at calculating your speed? Mine always says i'm going slower than my speedo says, by about 3-4mph. I always thought it was the sat nav that was out, but maybe it's more accurate than my actual speedo!
