Gti Front Grille
chewy
Gti Front Grille
Post by chewy »
Does anyone know if the Gti front grille on vagparts will fit an 03 9n? Or can you get the same style with the red edge from somewhere else?
Kim9N
Post by Kim9N »
Just do it yourself with tape, im a girl and even I managed it!
Helps if you heat it on with a hairdryer to do the corners etc!
chewy
Post by chewy »
Will give that a try. Where did you get you bonnet bra and how much was it?
Kim9N
Post by Kim9N »
I got my bonnet bra from AutoBra but I went through www.dubclique.com
They can get them cheap if you sign up and speak to Dan. :)
TDI_Burd
Post by TDI_Burd »
What kind of tape did u use? As i like this grill and would really like a chap mod at the moment lol
claire
Kim9N
Post by Kim9N »
I used Rim Tape from Halfords.
Tim_GTi
Post Whore
Post by Tim_GTi »
To get a good clean line with the tape on the grill, lightly heat it up with a hairdryer first, that way it will bend around the shape of the grill really easily, and also stick to it alot better!
chewy
Post by chewy »
I like the look of the gti grille better than the standard grille!
