Smoked Headlights
Hamish
Smoked Headlights
Post by Hamish »
Right. This morning i tryed to take apart a set of standard VW headligts to see if i could spray the inside of them black and get a set of smocked headlights for cheap.
Turns out VW plaster the things in sealent and its impossible to get then apart without breaking them IMO :evil:
What are my options?
The only aftemarket ones that i have seen are the those ghey angel eye ones, which i think look chav
Does anywhere sell RHD plain simple smoked headlights?
edit: something like these:
TimGti
Drives: 9n3 1.9 Tdi Sport
Re: Smoked Headlights
Post by TimGti »
Hamish wrote:Right. This morning i tryed to take apart a set of standard VW headligts to see if i could spray the inside of them black and get a set of smocked headlights for cheap.
Have a look on VWVORTEX.com in the Mk4 golf forum under the DIY threads/ use the search engine for 'Joey' Modded headlights. There was lots of threads about how to seperate and spray standard lights on there a while back. Must be possible as I know loads of people have done it on the MK4, sure they dont use different glue on the polo lights.... Turn the oven up more! :wink:
Hamish
Post by Hamish »
i couldnt find what you told me to search for...bit of help please? :oops:
The oven was only on gas mark 3, but they stayed in there for a while. Burnt myself :x :lol:
Even if i dod get them apart they would be all chewed up and not look very good tbh :(
edit: Tim. Like you say the glue is probs the same so given enough time it would melt, but the design on the 9n headlights is such thay you have to chew the plastic casing up to get a screwdriver in there to lever the glass out
Tim_GTi
Post Whore
Post by Tim_GTi »
I've heard of people using film to tint them, have you considered that? Not sure how good the finish is tho :?
Hamish
Post by Hamish »
Has potential, but that would reduce the overall performance of the lights.
Spraying the non essential parts on the inside wouldnt have any detrimental effectss
Tim_GTi
Post Whore
Post by Tim_GTi »
Ah ok, I imagine spraying the inside would look better also
Hamish
Post by Hamish »
any other suggestions :)
TimGti
Post by TimGti »
Hamish wrote:i couldnt find what you told me to search for...bit of help please? :oops:
Go here:
http://forums.vwvortex.com/zerosearch
Select archived content, set the forum (on the left drop down box) to search in golf iv & jetta iv and then type in the search section 'JOEY MOD'
Loads will come up
HTH
Hamish
Post by Hamish »
Cheers for that Tim. I can see mk4 headlights being easier to split compared to 9n headlights. I may give it another go 2moz night and just crank the oven up and see what happens :?
pidge87
Post by pidge87 »
Tinting the inside of your lights WILL affect the amount of light they put out!
The mirror finish as standard will reflect a much larger amount of light than a dark reflection surface!
If you are going to tint them i'd think about fitting HID's aswell :wink:
Hamish
Post by Hamish »
dont worry thats the plan ;). If i can god damn split them. Round 2 tonight. Ding ding
Hamish
Post by Hamish »
Round two failed :(. It really is impossible to split them :evil:
Tim_GTi
Post Whore
Post by Tim_GTi »
I'd just spray the outside or get the film then mate
Hamish
Post by Hamish »
ive got another plan in the pipeline :wink:
http://cgi.ebay.com/ebaymotors/VW-Polo- ... enameZWD2V
ive messaged them to see if they are LHD or RHD lights
Tim_GTi
Post Whore
Post by Tim_GTi »
ahh... they would save alot of time and effort 8)
