cant find anything on search, can anyone confirm that a 5 door standard interior will go in a 3 door car?
thanks!
5 door interior into 3 door
andyniceday
have done this in older vws (mk2 & 3 golf) and on those cars all the seats are the same, just in a 5 door they cover over where the levers go but underneath all the mechanism is present to make the seat tip forward. so you should just need to get the relevent handles and surrounding trims from the dealers, make a slice in the cloth and attach.
You could check for sure though with the seats out of the car. you will probable see there is a hook at either side on the rear of the base, connected to eachother by a rod. one end should have a cable on it whuch goes to where the release handle would be. if you release these hooks then the seat should tip.
(well this is how it works on the older cars anyway, if its tims seats you are after you could ask him to check, he might not mind whipping one out if it means he gets the sale
andyniceday
- Tim_GTi
- Post Whore
Yeh that does make sense actually, I get so claustaphobic (sp) in the back of 3-doors sometimes, woud hate for that to happen!DanDiesel wrote:i've heard from somewhere that if you have seats in the front of a 3 door that don't fold forward (ie- from a 5 door) then it could fail the MOT as the rear seat occupants would not be able to easily escape the car in an accident!
not sure how how accurate this is though
