Looney tuned project
dino
Sponsor
Post by dino »
Love it! Looks like a right beast...gotta respect the 5 door coolness 8)
Tim_GTi
Post Whore
Post by Tim_GTi »
dino wrote:gotta respect the 5 door coolness 8)
aye 8)
mk4 glx 1.6
Re: Looney tuned project
Post by mk4 glx 1.6 »
...Roadrunner... wrote:Chassis & Suspension :
KW variant 1
H&R front swaybar
Fitting a larger diameter front swaybar (I assume the H&R is) surely increases the understeer? I would have thought you would be better off with just a rear swaybar (ARB), or both front and rear, but certainly not just front?
Great looking car and nice (thoughtful) choice of modifications.
flyfs6
Post by flyfs6 »
Whoa. Awesome, just what I want mine to look like. The cup kit suits this car
Though I'd seen another one with just the front and rear bumpers, standard skirts and wheels - looked naff.
I might just settle for the low and phat look.
...Roadrunner...
Post by ...Roadrunner... »
KW variant 1
H&R front swaybar
First of all , thank you for your appreciation.
The H&R swaybar doesn't increase understeer. At least in my case, didn't. It isn't larger also, is is the same diameter as the original GTI one, but it has another shape. I needed the H&R swaybar, to eliminate the knocking that appeared on maximum steering to left or right, after lowering. The steering arms (that exit the steering case, and reach for the wheels) are touching the original swaybar when full steering to left or right is done, and produces a knocking sound. I'm sure that all of lowered GTI have that sound. This is were it camed from. Whit the H&R swaybar, the steering arm gets right around the swaybar, so no knocking ;)...
I have attached 2 pictures, first with the original swaybar, the second with the aftermarket one.
Dennis
Post by Dennis »
as I said on the other forum, mate your car is just awesome!great mods, great car!
any plans?!
...Roadrunner...
N75J valve fitted... Very nice results !
Instant throttle response, more linear boost, higher overboost...
whitegtipolo
Post by whitegtipolo »
how does the valve make so much differnce, if so how come its not fitted standard??
Jeff GTi
Post by Jeff GTi »
i also love the difference from my n75j valve, another lad on here used the n75h but got limp mode, but using the j varient i have never had a problem with mine
...Roadrunner...
whitegtipolo wrote:how does the valve make so much differnce, if so how come its not fitted standard??
The standard N75 is very good for standard engines. Mine is remaped, and the standard valve is out of range working with increased turbo boost.
The J valve is working very well with higher boost levels... Get it ?
whitegtipolo
I get what you mean getting mine remapped shortly off www.more-bhp.com vag remappers , how much is the boost valve n part number ??
