Turbo Problems? *sorted*
KennyPOLO_Gti
Post by KennyPOLO_Gti »
Sorted, Took my DV off the car today and put it on the test rig at work. Checked the vaccum first and it was liftin the piston fine, then put a constant air flow thro the inlet and it started fluttering about 0.2/0.3 Bar where it should be until I lift the throttle. Gettin a new DV today from them, may aswell use my warrenty!
