It's 'THE' hot question of the modding scene I believe.
Couple of options have been suggested so far.
1. Redrill the wheels. It's been done and it looks 'ok'; that is, the holes slightly overlap. You need wheels with caps that cover the holes for this.
2. Custom made adapters. I know a guy that ran GTI wheels (the Mk4 ones) on his 4-stud 6N, using custom made adapters. Apparently, it worked. They were 17mm thick IIRC. AFAIK, no one as yet makes these for the general public.
I know fitting new hubs etc would be a right pain in the @ss, but isn't that the best and strongest solution? I'd be wary about making adapters, it's the only thing that connects you to the road, after all....
If you got the golf hubs, you'd automatically be uprating the brakes - two birds with one stone?
Hubs could work. There's a VR6 Mk4 somewhere in Germany that has full Golf VR6 brakes/hubs, or so the owner claims. It has 5 stud wheels though so he must be right.
