My Polo's filling up like the titanic!
Dan 6N
Post by Dan 6N »
Sorry to be a noob, but I've got the same problem but unfortunately I have no idea where the pollen filter is, any help would be appreciated.
Thanks.
jonnopolo
Post by jonnopolo »
Passenger side scuttle, under the wipers. Open the bonnet and remove the passenger side scuttle plate (black plastic thing) and the rubber strip at the bottom of the scuttle. There are 2 clips to remove (or break) in order to remove the scuttle. Once you've removed it, you will see the pollen filter. Just renew filter, clean out the debris and replace everything. Job's a good 'un!
Polo96CL
Post by Polo96CL »
^ What he said, he helped me out last time so thanks again.
I was going to finish off spraying my front badge today, unfortuantly the can of black spray I had has broken on the nozzle :x
