How To For.....
Ian_R
How To For.....
Post by Ian_R »
Removale of the rear wiper.
can't seem to find one on the board, who has made one or has a worlking link?
olop_chris
Sponsor
Post by olop_chris »
Pull the nut cap up, unscrew the nut, pull the arm off.
Open the boot, take the plastic covering off the boot lid on the inside.
Un-screw the 3 bolts that hold the motor in, and pull out.
Place a little tiny screw or something in the washer pipe, so that it doesn't leak in your boot!
Find a suitable sized grommet to put in the hole in the window! (Can pick up different sizes from halfords for a few quid!)
Job done!
adam_0612
Post by adam_0612 »
on the plastic covering on the boot where the handles are remove them two screws then unclip the cover all the way round (be carefull as clips are very sensitive, i managed to break two of mine)
cut the pipe off from the motor that the water comes through and seal it off.
unscrew the 3 bolts on the motor and remove the plastic casing from outside of the wiper and unscrew the large bolt on the back.
the motor and wiper should now be easy to remove
use a 24mm grommit to fill the gap where the wiper was and a bit of sealant
job done
Si_GTi
Moderator
Post by Si_GTi »
I'll be undertaking this job in the next few weeks at some point so will take some photos and do a write-up 8)
olop_chris
Sponsor
You don't need a write up to be honest, it's as easy as pulling the front grille out! :lol:
