need help/advice on vw locking nuts
loud
Location: 25 miles south of Aberdeen Drives: 9N3 Polo GTi
Post by loud »
My cars in a garage and they are sayin they can't find the locking wheel nut, searched the car many times and no sign of it, I phoned the folk I bought it from who fitted two tyres before I bought it so used the nut and they are just saying it'll be in the car...but it looks like it isn't.
they are saying to remove and replace the bolts it'll be like £150 cos of the time it'll take...
can you get a replacement key or anything? It says in the handbook the code for the nut is on the nut itself...that's handy.
I really don't know the best way to go about it, I'm absolutely furious so not really thinking straight
Tim_GTi
Post Whore
Post by Tim_GTi »
VW dealers have a mastr key that will work on it. I don't know what you have to do to get them to do it for you though
MateyGuv
Sponsor
Post by MateyGuv »
I'm fairly sure the VW locking nuts only have about 20 variations so you should be able to order a new one through parts with your chassis number for about £20
M@Turner
Post by M@Turner »
£150 :shock:
Thats a load of rubbish! You can get hold of a kit which has lots of different attachments for removing locking wheel nuts without the special bolt!!! It ruins the locking wheel nut but then you've only gotta pay for a new set!!! £15 approximately.
Pretty sure Bstardchild has a kit!
kc
Drives: an imaginary one... for now
Post by kc »
get a cheap 18mm socket, hammer, 10 mins....
...happy times... lol
Tim_GTi
Post Whore
Post by Tim_GTi »
I think it's more around 50 different variations. Any dealer should be able to help you out though.
loud
Post by loud »
cool i'll check around, there's no way i was going to pay that much money for something like that!
cheers for the replies
pip_polo
Post by pip_polo »
Tim_GTi wrote:I think it's more around 50 different variations. Any dealer should be able to help you out though.
as said, there are over 50 combinations, i'm sure if you took it to VW explained whats happened and proved the car is yours and stuff they could help you..
kc wrote:get a cheap 18mm socket, hammer, 10 mins....
Exactly, and now a tip for everyone else, go and get that key and note down the ident on it - just in case.
I'm sure that there will be a way to "decode" the damaged, but removed mystery security bolt - then just get VW to order you in a new set with that coding - must be possible even although they would rather just sell you a new but random coded set.
flyfs6
Post by flyfs6 »
Check the tool kit/vinyl pouch thing. There's a little compartment/pocket within. It maybe in there, thats where it was in mine from new.
whitegtipolo
Post by whitegtipolo »
if you live near me ill get em off have a special too we do cos we need it for our job when doing a spare wheel and they dont have a lock nut ! Has loads a attachments and a impact driver! :lol:
david burton
Post by david burton »
don't get anyone other than VW to sort it out. there's no point in getting someone to force the locking bolt off.
just pop to VW and explain you don't have the "key". They'll get a kit and offer up the various types of master socket until one fits. it'll cost about 16 quid for the replacement.
have a closer look in the boot though, as mentioned above. I did this exact process on my passat and the thing was actually hidden in the aforementioned pouch!
david burton wrote:don't get anyone other than VW to sort it out. there's no point in getting someone to force the locking bolt off.
If you do go down this route, why not get them to remove all four security bolts and buy four new ordinary ones to fit while the new adaptor is being ordered - or just buy a new locking wheel bolt kit if time and fuel is a problem.
When this happened to my mate with his Saab, local tyre fixer just whacked on a "tight fit" socket - no wheel damage but one locking bolt wrecked. He had a serious word with his garage "did you try removing the spare wheel - we sometimes just throw it (the adaptor) back in" they said. They were right, but as always best to check up on these things BEFORE you need to use them,especially when buying a used car.
alexperkins
Site Admin
Post by alexperkins »
There are 57 combinations of VW locking bolt. Most good dealerships hold two sets of master removal nuts and should just let you use the correct one when asked for. We always did anyway!
