Dodgy Aerial/Base
Dodgy Aerial/Base
It seems since i've had the car all i've had is problems!
so, the car (6n2) came with one of those crappy aluminium look aerials from halfrauds. So i ordered an Sk aerial the other day from ebay. The aerial came today, except when i went to unscrew the existing aerial it wouldn't budge. So, i whipped out the mole and it started moving. But it's not actually unscreweing. It's turning, but not going anywhere, which means that the aerial was either the wrong size and has been rammed in ther so badly that the threads aren't threads anymore, or its just broken...
in either case, im PISSED!
any ideas?
tar.
any ideas?
tar.
DanDiesel
- Sponsor
are you sure its not an anti theft aerial? could have a ball on the end which you remove by just giving it a good tug!
put a towel behind the aerial on the roof so that it doesn't accidentally scratch your roof when it pops out, and make sure you don't bend the roof!
if it still doesn't budge then i'm not sure what you can do?
