My girlfriends 1.4 16V has been a good little car until the other day when depressing the clutch and bang! The pedal went to the floor. Pedal didn't come back up.
Upon looking, the metal bracket that holds the clutch cable in place which should be an attached part of the pedal box has litteraly snapped off. Oh joy!
A friend said this actually happend to his 2001/Y Golf GTi (Ours is also 2001/Y) and a garage I spoke to reckons they have seen it before on Polo's. So has anyone else had this problem? If so I wonder if it's a known fault maybe I could approach VW with some strength in the case?
It'll probably cost us around £2-300 to fix by the sounds of it so any help/advise would be greatly appreciated.
And then we'll sell it! (it's flippin clean by the way!!!)
How common is this fault?
me 2. only a couple of months ago as well. it wont cost u that much to fix it. however it u take it to a garage to fix it will cost at least, im guessing a coupl eof hundred as they have to remove the steering column. my god father did mine with the aid of the haynes manual. by the way i got a x reg 2000. if thats all u had your lucky.
so far in the last 2 years or so ive had:
engine rebuild
gearbox rebuild
new clutch
new battery
new pedal box
new break sensor
think thats it actually............
engine rebuild
gearbox rebuild
new clutch
new battery
new pedal box
new break sensor
Cheers for that fella's.
Kipper, From what you've been through I most certainly think it'll be time to change!
HOWEVER! Due to your confirmation of this being known I spoke to a VERY helpfull chap at a local dealers who did his bit and hey presto, 100% warranty covered. So now gonna drive it there without clutch. This will be interesting! can practice my clutchless gear changes I guess?
Thanks again.
Ps, Polo 16V for sale!
Thanks again.
Gentlemen!
We're all good, Clutchless driving is no problem if you're relaxed about it.
The only thing that can make it difficult is if you have to keep stopping/starting etc and other drivers get arsie/impatient. Although I found it quite comical, they think your probably 107 yrs old!
No really though, I had a good journey. Went quite smoothly with I'd say only a couple of very minor crunches mainly into third, all others slipped in nicley when the gearbox/engine speeds matched up. was about 10 miles I reckon.
Anyway it's comfortably settled at the dealers now and I'm very much looking forwards to my bill of £0.00! or at least the missus is!
Cheers again and all the best.
Gentlemen!
