i have treated it to some width, i have bought a set of B+ hubcentric spacers, these are the ones which bolt to the hub, using the supplied bolts in the kit, then the wheel bolts on to the spacer using the existing VW bolts
the kit is 30 mm track widening, so 15 mm per wheel, was going to go for 20 mm per wheel kit, but that would of took the wheel to an offset of 18, and would be likely to cause rubbing issues lowered 50/55 mm all round like mine is, so et 23 should sit in there just nice, provide a nicer stance and not rub ... result
cant wait for them to arrive, ill post pics up when they come, but could get to mid week being bank holiday and all
so dan, to answer the discussion we was having by pm, vemon can supply you with a 30 mm per axel spacer kit
iv also just ordered a full set of the gti centre caps for my monzas as the ones i have are getting a bit corroded and naff looking, so thats sorted now too, yet more improvements made,
jeff
