Anyone got an oil temperature gauge fitted?
alexperkins
Site Admin
Post by alexperkins »
Hi All,
Im after some advice. Im wanting to install an oil temperature guage to make sure the engine is running at optimum temp before pushing it a little.
Has anyone done this, and if so where is the gauge mounted, and how does it work?
Alex
bbspolo
Post by bbspolo »
no need alex u can get an oil temp reading (along with alot more) desplied on the aircon screen!
ill dig the details out later and pm them 2 u!
alexperkins
Site Admin
oh thats fantastic! If you could do that, id really appreciate it :)
MaxZ
Post by MaxZ »
I know that to operate it, you need to press Cold Air, Down and Econ buttons, and then you use red/blue (Hot/Cold) to look through the channels.
Not sure which channel is for oil temp. though
tegwin
Post by tegwin »
I didnt think it displayed the actual temperature....just a number converted from the analogue signal~?
bbspolo
Post by bbspolo »
no its the correct temp ! all it does is converts the code 2 somthing thats readable just like 5052 does infact it uses all the same codes as 5052 so it can desplay alot more than oil temp !
alexperkins
Site Admin
So ye, if you could PM me the details on which channels do what, that'd be sweet :)
Tim_GTi
Post Whore
Post by Tim_GTi »
Are you guys saying that the oil temp is obtainable by pressing certain buttons on the climatronic?
Or that you can modify it to use the same screen?
kinder
Post by kinder »
yer if someone can pm me the details on how to find this out it would be great cheers
bbspolo
Post by bbspolo »
yes u can get oil temp and actual speed up on the desplay (and a few others) by pressing a few buttons will dig out my old hard drive and find the instructions!
or ebay it up !! :wink:
Tim_GTi
Post Whore
Post by Tim_GTi »
If you could find them Dan that woud be great!
What else can it display?
MaxZ
Post by MaxZ »
Channel 1 is outside temperature, Channel 16 is speed in KM/H.
Link for further explanation.
The buttons you need to press are Fan Down, Temperature Colder and ECON at the same time. Press ECON to exit.
Know English Channels,
1 Interior temperature (sensor)
3 Sunlight sensor
7 Coolant temperature sensor
9 Blower speed (adjustable)
10 Measured blower speed (sensor)
11 Defog valve (adj. 0-255)
12 Dashboard ventilation valve (adj. 0-255)
13 Recirculation valve (adj. 0-255)
14 Lower ventilation valve (adj. 0-255)
16 Speed (sensor)
http://www.compartelo.cl/upload/37693/c ... tronic.pdf
alexperkins
Site Admin
Awesome :) cheers max. I dont see any oil temp on there tho?
Tim_GTi
Post Whore
Post by Tim_GTi »
Cheers Max, thats awseome 8)
will go and have a play with it now
MaxZ
Post by MaxZ »
I've added it to the Polo GTI Mods Sticky, so you guys can use it as a referencing tool.
