1.6/1.4L 8 Valve engines...
Rmachines
Post by Rmachines »
Hi if i was to get hold of a 1.6L AEE lump i guess most of the parts would fit from the 1.4L its just the fueling side of it. Are parts like the intake manifold the same, and the throttle body/injectors/ECU etc.. Or is it all diffrent size parts for the 1.6L? All i know is it looks the same :D
Cheers!
JarnoVWPolo6N
Re: 1.6/1.4L 8 Valve engines...
Post by JarnoVWPolo6N »
Rmachines wrote:Hi if i was to get hold of a 1.6L AEE lump i guess most of the parts would fit from the 1.4L its just the fueling side of it. Are parts like the intake manifold the same, and the throttle body/injectors/ECU etc.. Or is it all diffrent size parts for the 1.6L? All i know is it looks the same :D
Cheers!
It looks the same, onthe outside, internally it's all different. Bigger bore/diameter inletmanifold, higher capacity injectors, slightly differente throttle-body, the AEE has it all, just no difference in ECU though :wink:
JoeG07
Post by JoeG07 »
Are you planning on doing an engine swap from a 1.4 to a 1.6??
Rmachines
Post by Rmachines »
yes my 1.4L engine is totaly knackerd, serious piston slap so soon to crack a piston.
I can get hold of a tall block 1.4 or 1.6 but would like to fit a 1.6 if it doesnt mean to much forking out on new parts. If i can find one with the mainfold and injectors that would be great!
polo-sib
Post by polo-sib »
Sorry to hijack the topic, but how does the bore differ and would the 1.4 pistons still fit into the 1.6 bores?
Rmachines
Post by Rmachines »
its a diffrent stroke im not 100% sure if there actualy a diffrence on bore?!?
Rmachines
Post by Rmachines »
Does any one know if the engine out of the Golf would fit? Its the same engine but has diffrent engine mounts it doesnt have one by the cambelt cover. Would i be able to bolt it into place?
JarnoVWPolo6N
Rmachines wrote:its a diffrent stroke im not 100% sure if there actualy a diffrence on bore?!?
1.4 AEX & 1.6 AEE/AEA have same bore, only differ in stroke
Rmachines wrote:Does any one know if the engine out of the Golf would fit? Its the same engine but has diffrent engine mounts it doesnt have one by the cambelt cover. Would i be able to bolt it into place?
Yes, will fit, you'll need to get the proper mounts onto it before fitting it of course :wink:
Rmachines
Post by Rmachines »
Ok thats great i will get hold of a 1.6L AEE/AEA engine then.
It will be a direct swap, all i need is the injection side of it? I plan to use my Megasquirt and fit TB's once its running :D
