what type of bulbs???
jus wanted to know what is the most likely type of bulb i've got in ny 2000 reg 6n2. want a set of hids
6n2 had two types of headlights.
It had the two square shapes on the inside of the unit (twin halogen) which has:
12v55w H1 & 12v55w H7 bulbs
Then you had the one with a square and circle on the inside (halogen and gas bulb) which used:
12v55w H1 & 12v35w D2S
The first one I described looks like this:
Hope this helps with your HID idea and a 6n2 is a mark 5 not Mark 4
For HID's I recommend the site listed below, as for which kit you need I'm sure someone can advise you:
hids4u.co.uk
hids4u.co.uk
- Tim_GTi
- Post Whore
Fogs are H7, full beams are H1, dipped beams are H7.
See here for HID kits:
http://www.hids4u.co.uk/store/home.php?cat=1
