boot light
kinder
boot light
Post by kinder »
does any one know how to get the boot light to work i have checked the bulb and fuse they are all ok but still no light
alexperkins
Site Admin
Post by alexperkins »
Itll be the switch in the lock thats causing it. Check inside the boot panel
kinder
Post by kinder »
ill have a look 2moz
Tim_GTi
Post Whore
Post by Tim_GTi »
Have you checked to see if it's plugged in also?
Mine came unplugged near the bulb. And also apparently there's a connector down the passenger side of the car under the carpet that is often unplugged for some reason.
kinder
Post by kinder »
yer its plugged it i checked tht 1st its never worked in 2yrs i had the car
bbspolo
Post by bbspolo »
do the other interior lights come on when u open the boot ????
if not its the switch like alex said! if they do then i would imagen u have a problem with your wiring! (as long as u have checked the bulb, connectors etc!)
alexperkins
Site Admin
The 6n2 polo interior lights are not linked to the boot - its two seperate lighting systems.
