fitted my rear handle today, you do not need to modify the lock barrel as the niel did, simply use your existing rear part of the handle and the new smooth front part of the handle, doing this the handle fits perfectly without making it stick out, it fits perfectly flush and good
the part number of just the handle part and not the full assembly is
6Q6 827 565 H
BUYING JUST THIS MEANS ALL YOU NEED TO DO IS SIMPLY USE THIS NEW HANDLE TO REPLACE THE OLD ONE WITH THE HOLE IN, WITH NO FURTHER MODIFYING OF THE SETUP
