[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 oil breather problems - UK-POLOS.NET - THE VW Polo Forum
i fitted a bmc yesterday and also fitted an oil breather to the left over oil breather pipe. where have you positioned yours as im getting a strong vapour smell coming through the vents and its making me light headed ha.
any pics would be great.
buy a proper catch tank (there only about 20 quid from the bay)
think about it do u reary want oil (if only tiny splaters) landing on your hot exhaust manifold???
these little oil breater filters have always been a bad idear and i remove every1 i c on cars i work on!
Either that or attach a piece of pipe that leads the breather filter to a different part of the engine, I need to do this. My passengers complain about the fumes, which I've now gotten used to lol
yer that one will work fine! its more of a case if u have some were it will fit!!
i bought 10 small round ones (same size as that though) about a year ago! which i fit down by the n/s headlight on the cars i work on (mat black though dont do shiny stuff)
i found this 2 be the best place as its easy 2 acess 2 empty from time 2 time and it looks quite ome !! i also bought a real of braided hose which i use 2 replace all the breather pipes while im at it! (standard ones melt/perish after a while)
how can the oil get anywhere near the exhaust manifold as that is at the front of the engine. maybe it will get on the inlet manifold but all thats going to do is make a mess and cant cause a fire as its coldish.
