Bumpstrip Problem
crodgers
Bumpstrip Problem
Post by crodgers »
Removed my bumpstrips the other day. Found that the passengers side was perfect and looks well. But when i removed the strips on the drivers side i realised that there is skim of laquer or something below where the rubstrip was. I have tried Autoglym Paint renovator and a good wash an polish but nothing seems to work, it just highlights this area.
Below is a pic -
Any Ideas?
iggy350
Post by iggy350 »
hum i have this 2, but my cars black its not noticable unless you are looking for it, but T-Cut might reduce the scale of it? I personally find T-cut the better option seems like it burns the top layer off :)
crodgers
Post by crodgers »
Thanks a may as well give it a go. T-cut was my first choice but the guy in the shop said that the Autoglym was what i needed :roll:
iggy350
Post by iggy350 »
Get the T-Cut in the Red bottle, its just powers through anything :) and stick some elbow greese into it :D
I stopped listening to shop assistants when they told me i needed to bore my centrebore of my Wheels :P
baileysufc
Post by baileysufc »
get ur self sum wet and dry 1500 grit and smooth them out abit then polsih them with farecla g3 and that will make it 100 times better
just remebr its a cuttign compand so if u polsih ur car with it every week u will eventually rub through
troy
Mike
Post by Mike »
I agree G3 is the way to go, T-cut is very harsh..Try a small test area and give it a go, it maybe just the unfaded area underneath which hasn’t been affected by the weather which just needs a little blending. What you’re trying to do is cut back the surrounding areas to blend with the strip.
crodgers
Post by crodgers »
Will this definately work? If you run your finger downwards you can feel the difference.
dubbegood
Post by dubbegood »
g3 for the win
Mike
Post by Mike »
could you post some pictures, it might sound like you had some work done on that side and they didn't remove the strips just masked them, then the clear coat has settled against the strip, as the other side seems fine this maybe be what happened..
crodgers
Post by crodgers »
Tried the 1500 and the compound. Didnt work unfortunately. And actually rub through a tiny bit. Going to get a price for a respray or else the strips will have to go back on!
